hard drive sata connections
Solved by Mira Yurizaki,
SATA has the following advantages over USB, at least when it was developed way back when (what was it, 2004?)
- USB back then was limited to 480Mbps (or 60 megabytes per second). After overhead, it's really more like 40 megabytes per second on a good day. IDE's maximum speed was 133 megabytes per second. SATA's first generation is 150 megabytes per second.
- USB 2.0 and earlier is single duplex. To a storage drive, that means you can only read or write. Granted, while they probably don't do both at the same time anyway, you couldn't for example, issue more commands to the drive while you were reading something.
Purpose built protocol for storage drives. Technically you could do a USB to SATA but that's still overhead
- I'm also not sure how complicated the USB protocol is, but I'm sure it's more complicated than SATA due to USB's more generic purpose nature.
