I have a Lenovo laptop that I bought a few years ago for $250 that had a Pentium it. Little did I know at that time what a Pentium processor was and after barely using it throughout the few years, the computer can barely even function. I had built a pc a couple years after buying that laptop and it’s been working great at home. It came to my mind that maybe if I sell the laptop and pay a little bit from my own pocket, I could get a functional pc for work. My budget is $250-$300 and I do not think a graphics card would be needed but if there were integrated graphics i would love it. I have my own 500gb hdd so that saves a few too. My first question is what is a good processor I can get with power, reliability, but also a little easy on the budget? Second, what case can I get that is compact but easy to build in? Third, what cheap psu is good for this build?
https://linustechtips.com/topic/908563-250-budget-build-for-work/
What does the current desktop have? Are you planning to upgrade it or build a new pc? And for a cheap psu look for a good brand name psu and please don't cheap out on some off-brand weird one. If you upgrade the pre built get a new PSU. Someone else posted recently that their pc died from upgrading the pre-built and not changing out the psu.
Discord: Skyline#0820
Literally an idiot, don't listen to me.
Main computer: i5-4690k 4.3GHz, Noctua NH-D15, Nitro+ RX 580 SE, 16GB Corsair Vengeance, Samsung 840 series 128GB Crucial MX500 2TB, WD Purple 3TB, EVGA 600w, Dell s2240m 1080p 60hz, Corsair K70 Cherry MX Blue, Logitech G502 Hero.
Asus GU501gm
Just buy any old business machine from dell or HP that has an i5 or i7 and 8GBs of RAM
Or buy any older Thinkpad or business laptop with an i5 or i7 for your price point
Even a lowly Ryzen APU build is $99 for R3 2200G + $75 for ASrock Pro4 + 70-90 for DDR4
I do have some old PCs laying around and I think that they are so old that I can only really use the Hard drives. It’s a partial new build though and about the PSUs... yes I will look into a good brand name one but I kinda want something that is at least under 50$ with maybe an 80 plus bronze.
You should be able to find something under 50$, I'll go take a look at some good ones I can find. Do you know what parts it's going to have or the wattage it will require?
Asus GU501gm
That was almost exactly the parts I was planning on using (the third option) but I’m thinking of just using 4gb of ram so that’s cheaper and a problem I’ve ran into is the motherboard bios may not natively support raven ridge so how do I find a board that does.
Some newer ones should support it. Just search for some, and if you need to get the free cpu thing amd offers for free which you send back later. Also if your case fits a atx power supply here's one. https://www.amazon.com/EVGA-BRONZE-Supply-Warranty-100-B1-0500-KR/dp/B00DZ6R9GE/ref=sr_1_3?ie=UTF8&qid=1521747893&sr=8-3&keywords=atx+psu+80+plus
Asus GU501gm
A basic 400w will be plenty because there is not even a graphics card. And no need to be modular because a normal psu will be cheaper (unless you find such) and thx for researching some.
Thx I will for sure keep that on my parts list and I’m looking into the loan CPU program from amd
No problem. Once you start going cheaper you start running into crappy ones. Just make sure it will fit in the prebuilt pc if you use the pre built case. Most of those use smaller ones. Check the outside of the psu in the pre built and see if it's ATX or something else. If it's smaller than ATX then look at silverstone's SFX ones which are a lot smaller but a little expensive.
Asus GU501gm
Ok and what about the processor
Just get a cheap used OEM. You can't save money by building something like this from scratch unless you have a crap ton of free time to waste.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
What processor you want to buy? You could get a ryzen apu or some lower end intel one with integrated graphics.
Asus GU501gm
Sandy bridge? Because a price an i5 8400 is for some reason almost exactly the same as an i5 Haswell. And can you give me some insight if it’s worth going a platform that supports ddr3 and get 8-16 gbs of that instead of 4gb of ddr4?
I have a 4690k, which is a pretty good chip. What exactly are you going to do with the PC that requires enough power? The chip you want depends on what your doing with it.
Asus GU501gm
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($98.90 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($95.89 @ OutletPC)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case  ($18.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($23.98 @ Newegg)
Total: $297.75
Generated by PCPartPicker 2018-03-22 22:09 EDT-0400
Total: $297.75
OMG! Thx for the research and the time that you put into finding a set of parts for me i really appreciate it. That looks like a good setup and even 8gb of ddr4 is awesome! I will try to see what i can find to lower the cost if any but my budget should perfectly fit that build. Thx
Multitasking (microsoft office, while internet browsing and also running a sometimes resource intensive security camera application) and that should be it
Ok, the post above looks good, you could always try looking at older intel chips that use ddr3 which might be a little cheaper. But 98$ for that cpu is a good deal. I would say go with that one above.
Asus GU501gm
