what cpu cpu cooler should i get?
Ofir aviel
hi there,
recently, my old cpu cooler's fan broke (its still runs, but its not cooling the cpu enough, the cpu gets to around 58 degrees
(this is my family's computer btw)
here is the specs:
CPU: Intel Core i7-4790
motherboard: Gigabyte GA-H87M-HD3
thank your for helping,
ofir aviel
58 on idle isn't great but also isn't even close to dangerous. If you really feel the need to upgrade a classic choice is a Hyper 212 EVO, although I personally prefer the Cryorig H7. If you need something smaller, try a Noctua L9i or a Cryorig C7 (I've used all of these)
What cooler is on the machine atm? as you may be able to just replace the fan.
Wraith/Main Rig: AMD Ryzen 7 5800X3D | DeepCool AK620 | ASRock X570 Steel Legend | Micron Workstation ECC 64GB | XFX Speedster SWFT 319 Radeon RX 6800 XT 16GB | Topping D50s+A50s+PA3s | Seagate FireCuda 520 NVMe 500GB, Samsung 860 EVO M.2 1TB, Samsung 970 EVO Plus NVMe 2TB, HPE SSD 1.92TB, Toshiba X300 4TB, Seagate SkyHawk 4TB, WD Blue 4TB, HPE HDD 8TB | LG GGW-H20L Bluray-RW, Pioneer DVR-220LBK DVD-RW | HP NC550SFP 10GbE | Super Flower Leadex II Gold 750W | CoolerMaster MasterCase MC500P - Ghost/Test Rig: AMD Ryzen 7 1800X | Scythe Mugen 5 Rev.B | Asus ROG Strix X370-F | Crucial Ballistix Red 16GB | ASRock Intel ARC A770 Phantom Gaming D 8GB | Asus Xonar D2X | Crucial MX500 250GB, Seagate BarraCuda 500GB | SAMA Forza 750W Gold | Antec GX200
Phantom/Win98 Rig: AMD Athlon XP-M 2500+ | Arctic Cooling Copper Silent 3 | ASRock K7S41GX | Elixir 512MB | ATI Radeon 9800 XT 256MB with ATI Silencer 3 Rev.2 | Aureal BA88DL30A-01 Vortex 2 | Seagate Barracuda 160GB | LiteOn IHDP118-18 DVD-Rom | Samsung FDD | Ccivo 300W | CiT S008B - Parvati IV/Home Unraid Rig: Dual AMD Opteron 4184 | 2x Noctua NH-U12DO A3 | Supermicro Aplus H8DCL-i | Samsung ECC 32GB | Matrox G200eW 16MB | Kioxia Exceria G2 1TB, HPE Seagate Exos 4TB, 2x Seagate Barracuda Green 2TB, 2x Toshiba E300 2TB, Seagate SkyHawk 2TB, 2x Samsung Spinpoint F4EG 2TB, Seagate Essentials 1TB, WD Green 500GB | Dell Perc H200+H310 HBA, HP NC550SFP 10GbE | Cooler Master MWE v2 850W | Corsair Obsidian 750d Full Tower - Behemoth12/Second Unraid Rig: HP Microserver G8 | Xeon E3-1220L V2 | Intel C204 | Hynix ECC 16GB | Matrox G200eH 16MB | WD Green 500GB NVMe |
I have a Cryorig H7, and it performs very well. I did change the fan to something with higher static pressure, and only really changed temps about 1 degree. Then again, the room the rig is in is not ideal conditions. Maybe that has something to do with it.
More on point, if you're planning a full replace, the Cryorig H7 and be quiet! Dark Rock 3 series is a fine way to go for air coolers if you can't afford (or don't like) Noctua products.
Ultrima Z238EC: Ryzen 7 3800X @ stock, Enermax AquaFusion AIO w/ 2 be quiet! Silent Wings 3 fans, ASRock Taichi X570, Zotac Geforce GTX 1070 AMP!, 2x8GB TeamGroup Dark Pro 3200MHz, Lian Li Lancool II Case
A lot of people Probably Still have the trusty Noctua D14 and that thing can be mounted on just about anything. I would use that for Airrrr.
  • 3 weeks later...
i am not actually sure what is that cooler
Can you post a photo of it?
What are your load temps and what were your temps before?
