Best option for the monitor cables.
26 minutes ago, JohnnyCyp said:I used the supply cables that was in the box of the monitor, which is hdmi 2.0 and display port 1.2 high speed, but i already bought this hdmi and displayport. If i used theses cables, it's possible to have a better image quality ? One of the reasons that i have doubts about the displayport cable that i bought, it's because it's supported encryption System: HDCP 1.3 and my monitor support HDCP 2.2, so the supply displayport cable must be support HDCP 2.2 right? And another thing the first time that i turn on my monitor i got this message : CAUTION USE SUPPLY CABLES
Short Answer: No, you wont get better image quality.
Long answer: You might run into some issues when you're trying to stream netflix oder Amazon or whatever because those might require that everything supports the HDCP 2.2 Standard. You will not be reduced to less quality or resolution it will simply not show anything. But HDCP is something that is worth a topic itself. Assuming the spplied cables are good you'll get the max resolution you Monitor can display through them without any problems. With digital signals all you're gonna get is qrtefacts in the image like flickering green spots or some noise.
