Could it be possible to affix a 12v Peltier chip to a cpu, and use something like a Hyper t2 to cool it (it's the only heatsink I have laying around) what would be the temps I would get? (Currently I5-3570k@4.3ghz 65C on water) what would I need to do to my mobo to prevent condensation and all that bad stuff?
https://linustechtips.com/topic/907401-peltier-cooling/
3 minutes ago, tydraestor said:
I see. Worse temps I'm assuming
The problem with Peltier cooling is that you need a beefy cooling system on the hot side. Otherwise you burn the unit out.
You may as well just use the beefy cooling system on the CPU directly.
EDIT: Quick look at the Hyper T2 is it's a 130W TDP cooler. Yeah, that's not going to remotely cut it.
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11153444
That makes sense. On the ebay listing it had a small heatsink, and I knew it wouldn't work
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11153451
I currently have an Corsair H50
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11153454
You need a dedicated loop to deal with the hot side of peltier cooling pads.
Blocks like this: https://www.ebay.co.uk/itm/40-80-12mm-Aluminium-Water-Cooling-Waterblock-Heatsink-Block-Liquid-Cooler-For-C/282699428652?epid=23014687178&hash=item41d232f32c:g:vyMAAOSwj99Z53vI
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11153460
37 minutes ago, DildorTheDecent said:
I was thinking just mounting the Peltier to the cpu
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11153643
You could but it won't be as effective (i think) + have fun mounting that. Might run the risk of breaking the peltier module.
Buy a few of those blocks, have one loop to cool the peltier and the other loop to carry the chilly coolant to the CPU. Those are aluminium so watch out.
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11154051
Check out overclock.net forums, there is a big section on peltier cooling. Its alot more work than u would think to get good temps.
TEC cooling is highly inefficent, but capable of subzero temperatures with enough work and money thrown in.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11154153
There's a reason literally no one does peltier cooling.
If you want to go extreme you either do direct refrigeration on the CPU or a water chiller.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11155236
Takes me back 10 years to [H]ardforum when it was done.
Living Room: HTPC (M1 Mac Mini 8/256) HiFi (Furman Elite-15 PFi > Cambridge 851N > Emotiva A300 > Focal Chora 826) Display (65-inch LG Oled, 22-inch Dell)
Office: Workstation (AMD 3900X, RX5700XT, 32GB) Headphones (Cambridge DacMagic+ > Schiit Lyr 3 > DT 990. 2 Sonos One in Stereo) Display (32-inch Gigabyte)
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11162098
I do get an erection imagining using 3000W of power to cool a 500W CPU , but it's still just a terrible idea when there's better ways to go about it :P
https://linustechtips.com/topic/907401-peltier-cooling/#findComment-11162136
