HEELLPPPP,
So I built a  new PC with an 8700k and a 1080. I fired up OW and some other games and it was smooth sailing, was easily pushing 300 fps on low settings and only using 50-60 percent of my gpu, I installed FF14 last night, played for a bit. then went out. came back, fired up my pc and now my frames in OW or down to 120fps on low settings and my gpu usage is at 100%. I dont know what changed or what to do, I reset my pc. that didnt help MY thermals are fine.
https://linustechtips.com/topic/907310-help/
2 minutes ago, GoGoFerret said:
what should my clock speed be at while gaming?
That depends on what specific graphics card you bought.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/907310-help/#findComment-11152575
Just now, GoGoFerret said:
1080 fe
What is the name of the graphics card. For example I have a Gigabyte GTX 980 Ti G1 Gaming
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/907310-help/#findComment-11152582
1 minute ago, GoGoFerret said:
NVIDIA GeForce GTX 1080 Founders Edition
Ok. Bas clock should be 1607 Mhz and boost should be around 1733 Mhz
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/907310-help/#findComment-11152588
1860 to be exact
Ok. To test if the GPU is doing any funny business, download 3DMark to see if the GPU performs worse than the others.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/907310-help/#findComment-11152594
Bro, I didn't read your post yet. (I will read it and try to help) PLEASE - FOR THE LOVE OF ALL THAT IS HOLY DESCRIBE YOUR TOPIC IN THE POST TITLE. #1 thing that triggers me for real. /rant
Okay, now I'm reading your post.
Try these one at a time until its fixed -
1. Do you have a gsync monitor?
1.A If yes, try switching in and out of windowed mode in overwatch.
1.B Turn vertical sync OFF in overwatch and esnure you aren't using the display based fps limit in the overwatch settings.
2. Uninstall ALL of your graphics drivers using DDU
2.A download and install the latest nvidia drivers.
3. Make sure to reply even if you fix it to help others in the future.
CPU: Ryzen 5950X Ram: Corsair Vengeance 32GB DDR4 3600 CL14 | Graphics: GIGABYTE GAMING OC RTX 3090 |  Mobo: GIGABYTE B550 AORUS MASTER | Storage: SEAGATE FIRECUDA 520 2TB PSU: Be Quiet! Dark Power Pro 12 - 1500W | Monitor: Acer Predator XB271HU & LG C1
https://linustechtips.com/topic/907310-help/#findComment-11153892
My apologies, It was a late night full of depressed troubleshooting lol.
IT's not just OW, any game including furmark, I unistalled all the drivers with windows uninstall but not DDU does it make a difference?
https://linustechtips.com/topic/907310-help/#findComment-11153950
