I'm sure some of the below could be tweaked. Keep in mind that it would be best to buy local on the motherboard to see if it's got the latest BIOS or have a backup plan of knowing a local shop that will update the BIOS for cheap/free. Additionally, if you go with option 1 and there is a little extra, squeeze in the 2400G instead.
Option 1:
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($99.88 @ OutletPC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3000 Memory  ($93.99 @ Newegg Business)
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive  ($74.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.89 @ OutletPC)
Case: Rosewill - FBM-X1 MicroATX Mini Tower Case  ($30.13 @ Amazon)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($48.89 @ OutletPC)
Monitor: BenQ - GL2460HM 24.0" 1920x1080 60Hz Monitor  ($119.00 @ Amazon)
Total: $570.76
Generated by PCPartPicker 2018-03-17 13:39 EDT-0400
Option 2:
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($94.00 @ Amazon)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card  ($214.98 @ Newegg)
Total: $779.86
Generated by PCPartPicker 2018-03-17 13:40 EDT-0400
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/906793-build-for-a-friend/#findComment-11147713
Hey!
Take a look at this build, it is similar to Luricks but I changed some things so it would be closer to budget:
Storage: Kingston - A400 120GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Case: DIYPC - MA08-BK MicroATX Mini Tower Case  ($28.67 @ Newegg)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Monitor: Dell - SE2417HG 23.6" 1920x1080 60Hz Monitor  ($108.00 @ Amazon)
Total: $715.50
Generated by PCPartPicker 2018-03-17 16:29 EDT-0400
https://linustechtips.com/topic/906793-build-for-a-friend/#findComment-11148206
This is much better build...
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor  ($167.21 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Case: NZXT - S340 (Black/Blue) ATX Mid Tower Case  ($43.99 @ Newegg)
Monitor: Acer - V206HQLAbd 19.5" 1600x900 60Hz Monitor  ($83.00 @ Newegg)
Total: $548.95
Generated by PCPartPicker 2018-03-18 15:06 EDT-0400
Just tell him to pop in a couple when you prices get low...
This PC can Still run games at 1080p at low-mid settings
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/906793-build-for-a-friend/#findComment-11150745
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor  ($141.98 @ Newegg)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($59.99 @ Newegg Business)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($87.99 @ Newegg)
Case: DIYPC - MA01-R MicroATX Mini Tower Case  ($9.63 @ Newegg)
Monitor: HP - 22cwa 21.5" 1920x1080 60Hz Monitor  ($89.99 @ Amazon)
Total: $675.44
Generated by PCPartPicker 2018-03-18 22:28 EDT-0400
https://linustechtips.com/topic/906793-build-for-a-friend/#findComment-11152012
Total: $548.95
900p monitor lol
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/906793-build-for-a-friend/#findComment-11152060
8 hours ago, JDE said:
900p monitor lol
$500 budget though...
Go fr acer predator series or benq zowie series monitors then??
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/906793-build-for-a-friend/#findComment-11152812
