What is a good cooler for E8500 Socket 775 CPU? I have a Thermaltake CL-PO497 standard aluminum heatsink with 92mm fan on it. I am wondering if that is enough. I was playing GTA4 ang it seem to have throttled back to 3GHz from it's rated 3.16 Ghz while playing. I noted stuttering after around 15 minutes. CPU hit 68 c. I had Hardware monitor running.I went with Tin for reading.
https://linustechtips.com/topic/906522-e8500-cooling/
Clean and repaste, the CPU is 10 years old after all.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/906522-e8500-cooling/#findComment-11145376
I don't believe Intel chips back then even had thermal throttling. If it was really throttling, it would be much more than a difference of just 160MHz. 68c for a CPU isn't terrible when under load.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/906522-e8500-cooling/#findComment-11145377
