DUAL MONITOR SETUP
Renegad
Hey guys,
I just bought second monitor and since I just recently got into streaming I wanted to use my old one as a second one. I have a problem when doing so.  The new monitor, Predator XB241YU, is running at 165hz. The old one is running at 60hz. When I am playing CS GO on the Predator alone I can fully experience the refresh rate. However, as fast as I run OBS on the other monitor witch chat, live events and stream preview, it seems like the refresh rate drops to 60s or even lower. I also experience small fps lagg.
Im running 8700k and gtx 1080ti. Anyone here have any solution for that? Any tips? In advance, thanks!
My friend, try to buy a new HDMI cable because you might have a pretty old HDMI cable. You need to have at least a HDMI 2.0 cable. Incase you keep experiencing the issue after getting a new version of a HDMI cable. Just reply to the thread.
Well HDMI doesnt support 144hz if im not mistaken. Im running DP on the Predator and I have checked other HDMI cables.
I think it's pretty normal that it drops to the refresh rate of the slowest monitor
So there is no way around it? Only solution to get other 144hz monitor? :/
No, you can have monitors of different refresh rates.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
So why am I experiencing this?
2 minutes ago, NoobCase said:
Problem is only when you stream?
`Thats what Ive have used as my baseline yes. Since there are moving objects in the background when i run SLOBS. When there is nothing on the second monitor, just the wallpaper, everything is fine.
I believe streaming / recording using OBS will have some overhead so your FPS might drop, but it shouldnt drop dramtically i dont think. Also you could try to tweak the settings in OBS (ive never used it personally) but im sure there are options that allow window capture vs monitor capture etc, try changing it to capture the whole monitor rather than a specific application / game ? see if that improves it at all.
Also might be worth while looking at the windows 10 gamecapture settings and turn them all off (if you are using windows 10)
all the above is just guessing though.
