hii,
i have a i7 8700k, a asus rog maximus 10 formula and 2 1080ti's and i would like to watercool them.
is there a specific order which is the best for temps or does it make no diffrence at all
ik would like to go with a pump and res combo and one 360 rad(and possible a 240)
thanks in advance
https://linustechtips.com/topic/905596-water-cooling-order/
It makes no difference at all but I most people would suggest putting the res before the pump. As far as temps go the loop order doesn't matter
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11135912
Yeah, the order does not make a significant difference.
Couple suggestions: Add the 240 along with the 360 because one 360 rad might be iffy with i7-8700k OC and 2x GTX1080ti.
Secondly, you would want to delid the 8700k if you have not already, because the TIM will be the bottleneck before your watercooling.
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11135923
The res has to feed the pump the rest of the loop order makes no difference,But you want to keep the tubing runs as short and as straight as you can.Like said 360 and 240 would be best if you want to overclock anything later on.Plus a little extra cooling can help you can run your fan at a slower rpm which is nice to have.
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11136257
by the way, does any one have experience with deliding a 8700k and maybe a suggestion for a tool?
because i was already looking in to it but not really found a quality tool.
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11137170
Der8auer's Delid Die Mate 2 seems to be recommended, but I have not used it before.
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11137404
i have used tthe delid die mate 2. super easy. take a look at my ncase m1 build log
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11137527
The most important thing you can do for any custom loop is use the best coolant mixture possible. I am here today to tell you about the best one I have ever found... it literally dropped my temps 10C! It is called "Blinker Fluid" and you can find it in any local auto parts store. Normally they keep it in the back, so you will need to ask the attendant at the desk for it. It is pretty cheap at about $6/gallon and keeps your loop nice and clean.
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11137651
Most use the diemate, some use the 3d printed ones you can find all over for cheap..... I personally still use a razor blade
Just depends which you feel safest with.
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11139208
my last question, maybe a but off topic but does anyone have exerience with the primochill vue fluid, bc i see a lot of good things like jayztwocents review but also alot of negative reviews. so like i think it will be fine bc my computer is almost always running so it cant clog up my components
let me know please...
https://linustechtips.com/topic/905596-water-cooling-order/#findComment-11141311
