GUI Stops showing when calculations too large?
DtrollMC
Hey guys, so I'm messing around with 2D arrays and simple terrain generation algorithms. I know that the two algorithms I wrote are not very efficient, but I have gotten the results to display under certain settings. However, when I try to increase the size of the matrix I am generating / displaying, all the steps are done but the GUI just never shows up. What could be causing this?
The source code is only a few classes, so it won't take long to check out. Don't judge the code too much as I just refactored how the UI was structured so things are still messy.
https://github.com/JLCarveth/Voronoi/tree/master/src/com/github/jlcarveth
I don't know the language you're using but a general problem with GUI solutions is the program tying up the main thread so it cannot handle events, that results in a "program not responding" or the GUI not showing up.
Try doing the actual work in a new thread so the main thread can keep on doing the message pump.
I will look into that. Haven't done any multi-threaded programming before. Using Kotlin
Never heard of Kotlin before but you could always write the array into a bitmap very easily to view the terrain as a height map.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
