Display port 1.4 at over 5 meters?
WhiteSkyMage
Is there any possibility that I could run a longer than 5 meters (16 feet) display port cable (1.4) and still get close to its max bandwidth (4K 90Hz possibly?) ?
Intel Core i9-9900K | Asrock Phantom Gaming miniITX Z390 | 32GB GSkill Trident Z DDR4@3600MHz C17 | EVGA RTX 3090 FTW3 Watercooled | Samsung 970 EVO 1TB M.2 SSD | Crucial MX500 2TB SSD | Seasonic Focus Plus Gold 1000W | anidees AI Crystal Cube White V2 | Corsair M95 | Corsair K50 | Beyerdynamic DT770 Pros 250Ohm
Maximum length for DisplayPort is 3 meters.
For longer lengths, you need an ACTIVE cable. If you find one that's v1.4 o v2.0 then it should be capable of the bandwidth required for 4K, but not sure about 90 Hz.
For example, this 10m cable is active, but the bandwidth is only 10.8 gbps (displayport 1.1) so it can't do 4k 60 hz. It can only do 2560x1600 60 Hz  or 4K 30 Hz.
http://www.hardwarewebwinkel.nl/kabels-adapters-converters/displayport/displayport-f/delock-cable-displayport-m-m-5-meter.html?utm_source=tweakers&utm_medium=cpc&utm_content=textlink&utm_campaign=pricecompare
certainly looks like 4k60 DP cables exist that go 5m :)
(any google searches I do all end up on dutch websites so I can't really help you with your search for this cable in a certain shop)
