the stock cooler
https://linustechtips.com/topic/904866-stock-cooler/#findComment-11129404
13 minutes ago, Marcos_6 said:
Hi, I am building a new pc and I am using an MSI B350 TOMAHAWK PLUS and an AMD Ryzen 3 1300x. What are some good choices for a stock cooler?
A stock cooler is the cooler that comes with your CPU. Anything else would be considered aftermarket. So basically anything that isn't sold by AMD (or Intel if you're using Intel chips), would be considered aftermarket. What is a good cooler? Well depends if you plan to overclock. But the Cooler Master 212 Evo is a good all rounder. But if you're overclocking, might want to get something a bit better.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/904866-stock-cooler/#findComment-11129407
How about a Cryorig H7?
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/904866-stock-cooler/#findComment-11129445
The Cryorig H7 has surpassed that as the choice budget cooler, but as everyone else said, the stock cooler will work just fine.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/904866-stock-cooler/#findComment-11131510
