I was wondering how many fans can be connected to the fan controller of the Define r4? Thanks in advance for any help :D
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
https://linustechtips.com/topic/90456-define-r4-fan-controller/
I believe there are 3 default connectors but if you buy some $1 Y-splitters you can have as many as you want really.
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1222254
Are they 3 pin or 4 pin?
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1222267
Question: How many people on this forum have the Define r4!?!?!
Everyone.
But yeah, OP. The number of fans is 3, but I kinda see the built in fan controller as meh. It's a switch that lets you choose from 5v, 7v and 12v. Kinda wish Fractal included individual knobs/sliders instead of the one switch for more precision.
Also, on another forum where someone asked a similar question, they got a response from Fractal that more or less said it's a bad idea to use adapters to overload the built in controller.
3pin, but I wouldn't stress the fan controller with ghetto rigging. Either connect via molex and resisters to not make it sound like a hurricane inside the case (sound proofing only works if the fans are also not obnoxiously loud) or get a fan controller with a lot more channels.
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1222268
3 pin.
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1222270
It's got 3 headers and each one delivers 30w of power so realistically you could plug 10 or so good quality fans into each of the 3 headers in the unit and it would still run them just fine
Thanks bud! :D
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1222284
Everyone.
Personally I like the 5v,7v and 12v. Thanks for the response mate! :)
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1222285
  • 3 months later...
Thanks bud! :D
Hey bud I had the same question and I was wondering how this worked out for you?  I'm so tired of using Corsair Link I want to punch it in the face.  It's so hit and miss when it wants to work.
Also, were you able to confirm that each channel can handle 30 wats?
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1801041
I'm running my define R4 right now, and it's great it is handling the fans fine. I am unable to confirm about the 30 watts being used, not sure how to check it and I doubt I have the equipment. Sorry buddy :c Hope this helps! I have heard many complaints about Corsair Link, I personally don't use it, but many threads in the corsair forums are about it being problematic.
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1805941
what case fans are you running??
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1807137
The stock ones
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1808858
Glad it works for you.  I ended up getting a fan controller.  I don't know if I trust that the R4's case fan controller can handle more than 3 fans.. Maybe keep that in mind.
And yea Corsair Link needs an update. Badly. Corsair seems to have put it on the back burner for now.  Anyway without it my computer boots so much faster too.
https://linustechtips.com/topic/90456-define-r4-fan-controller/#findComment-1817144
