Motherboard and Graphics Card Compatibility
Solved by Unimaginative Name,
Yerp, as long as you have a 16x slot open. If the PC is a prebuilt (doesn't appear to be per the spec sheet), make sure it can take a full height expansion slot (rules or measuring tape). 1050ti's sometimes have power connectors and sometimes don't. If your PSU doesn't have the proper connector, you could always get a molex adapter. If price is an object, you can also look at a 4GB GTX 960, about the same performance as a 1050ti.
