I've recently bought an AMD FX-8350 with 16gb DDR3 RAM on a AM3+ Mobo that only supports DDR3 RAM. It has a GTX 1060 6GB GPU. I bought it used and the guy said he could only get so far into whatever he was doing before something crashed, he said it was probably the RAM. So I order new RAM (2x4gb) 1866 Kingston Fury X or something in that nature. So I get the hard drive installed and the RAM installed.. After 3 hours of getting Windows 10 to finally install, I've gotten to the point of playing a game. I installed Team Fortress 2 as a lighter game just to get my feet wet. It crashes hard time before I even get to access anything on the main menu. I thought the heatsink and crap was super dusty so I spent some time cleaning that. And I go back to try to boot the game and it crashes hard time again. I'm starting to think it wasn't the RAM that was crashing it was the Mobo. Am I way out of my mind thinking that? It was okay for regular browsing, minimal crashes, but getting it to even play TF2, a super low end game, and it crashed. Help? Please?
https://linustechtips.com/topic/903614-general-dumbaery-issues/
Try reseating the cpu one of the pins could be bent and when it tries to rev up it crashes this happened to my system when i was transporting it in a car
https://linustechtips.com/topic/903614-general-dumbaery-issues/#findComment-11117091
2 minutes ago, Jasun said:
reset cmos?
If its not posting then it might be a cpu problem it could of fried itself because 50 deg in tf2 is very high
is it a stock cooler? or aftermarket
3 minutes ago, HulkVonSmash said:
It's a EVGA 500 80+ Bronze rating. No idea on the temp, but before I got into using it it was around 50* C
https://linustechtips.com/topic/903614-general-dumbaery-issues/#findComment-11117102
50 deg is nothing... ~70 deg is when you start worrying. But it can still be a cpu problem, just not a temperature problem.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/903614-general-dumbaery-issues/#findComment-11117107
I'm gonna have to take it into one of the PC shops in my area. I'm just getting into PC Gaming and I don't know near enough to DIY it.
8 minutes ago, Captinjigglesworth said:
ya but 50 deg for tf2 that game uses gpu not cpu
It was 50 deg just in the BIOS/UEFI menu. I don't know how to check it once it actually boots all the way.
https://linustechtips.com/topic/903614-general-dumbaery-issues/#findComment-11117117
50 deg in bios is worse than the stock cooler u will just be fine with a new cpu cooler and u should boot and be able to play gameslike normal
https://linustechtips.com/topic/903614-general-dumbaery-issues/#findComment-11117128
But then I'm also thinking it could be the Motherboard because the guy I bought it from literally told me it would crash after a while. He suggested new RAM, so I bought new RAM. Same issue occurred.
It has a Cooler Master CPU Cooler in it already, though. I want to say it looks like a Hyper TX3, but it's not quite.
Its the Hyper Cooler 212 Evo actually.
https://linustechtips.com/topic/903614-general-dumbaery-issues/#findComment-11117130
