Diffused LED strips for case lighting?
Revamp
I was wondering if anyone knew of any small diffused lights that would work with the Asus Aura Sync?
I am using the NFC Skyreach 4 Mini case which is very small with large, open, see-throughable ventilation holes. I was wanting to cast a soft lighting in the case so you don't really see the individual LEDS.
Osmium: NFC Skyreach 4 // i7-8700k (delidd) // GTX 1080 // 32GB DDR4-3200Mhz // 1TB 960 Evo M.2 // 1.1TB MX300 m.2
Peripherals: Razer Blackwidow // Razer Orbweaver // Razer Kraken // Logitech G502 // Logitech K830 // LG 34UC88-B
Usage: Adobe Lightroom // Adobe Photoshop // Web Dev // Recording Gameplay // Video Editing // Portable Gaming
you could get your usual with aura sync working led strips.
try to get one or some, where the LEDs are nicely tight.
then get some clear acrylic plastic in the thickness, that you can hotglue it to the case with the leds in between.
before making the case led acrylic sandwich, get some sandpaper in different grits, and start working on the acrylic.
the goal is to get a nice matte finish.
that then matte acrylic over the leds will diffuse the light, make it more glowing instead of spot on beams.
P.S: acrylic or plexi glass
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
Case, LED, acrylic sandwich xD
Looks like I may have to go this route. Just was hoping to find some that was slim and had a diffuser attached so I didn't have to go buy acrylic and DIY (I'm lazy LOL).
Thanks for the post!
They make diffused channels just for LED’s such as this.
http://www.performance-pcs.com/huake-0-5m-super-slim-recessed-aluminum-led-profile-without-flange-using-for-strip-within-12mm-black-frosted-lens.html
