Is it true that 970 GTX can't do higher than 85hz on 2560x1440 monitor?
Solved by Celador,
Well. Mystery has been solved by a new cable - now it switches to any refresh rate without any issues. Surprisingly switching to higher refresh rate also reduced the second issue of noticing pixels - on 100/120/144 they disappear completely and on 60 i can only notice them by being closer to the monitor. The funniest part is that i bought the only cable i could find which was cheap and said "display protocol 1.0".
How can an included cable be defective and only work partially is beyond my understanding.
