2 minutes ago, Vibora said:
1151 motherboard
That's not enough information, we need to know what CPU you are actually going for.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Just now, Vibora said:
8600k / 8350k
I recommend you get the Asus Prime Z370-A then.
زندگی از چراغ
150$ is really expensive for a Motherboard isnt it?
Do you have anything cheaper?
No not at all.
زندگی از چراغ
Well I thought at the MSI B250M Gaming first, but idk.
That board wouldn't work with the CPU's you are looking at.
زندگی از چراغ
5 minutes ago, Vibora said:
Wait, if they're 1151, why wouldnt they work with the these GPU's? (If you care explaining?)
Is it because like they dont support the 8th gen?
Even though the board and the CPU's you are looking at have the same socket, Coffee Lake has a different pin layout so not backwards compatible I'm afraid. If you want a cheap Coffee Lake board then I suggest you scratch the idea of getting 'K' sku  chips and look at locked ones and wait for either H370 or B360 boards to come out (H370 boards have been leaked).
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
I dont want to go crazy. Maybe you could suggest a mid level CPU for 1151? (Something like i5-4570 was back in 2013.)
Go for the i5 8400 and wait for H370 or B360 boards to come out.
زندگی از چراغ
AMD Ryzen 5 1600, is pretty nice.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
