So basically im looking for the smallest atx case.
In the summer i plan on giving my old parts to my younger brother, the only thing im keeping is my case and storage.
So all im looking for is a small cheap case that would fit a full size power supply and an atx board for as cheap as possible as we dont really want to spend alot on it.
Plain black design, doesnt have to be windowed. Just a cheap small atx case recommendations
Any help much appreciated
EDIT: Oh sorry im looking at the BitFenix - Nova ATX Mid Tower Case for those wondering and it sits at £25
https://linustechtips.com/topic/902396-smallest-atx-case/
This is the cheapest full size atx case i found from amazon: 39 dollars
https://www.amazon.com/Thermaltake-Versa-Computer-Chassis-CA-1B3-00M1NN-00/dp/B00J0NZ5N0/ref=sr_1_11?s=pc&ie=UTF8&qid=1520168186&sr=1-11&keywords=atx+case
This is a 34( 24 with the mail in rebate) dollar case from pcpart picker, looks much worse but is cheaper:
https://pcpartpicker.com/product/sB3RsY/rosewill-case-challenger
https://linustechtips.com/topic/902396-smallest-atx-case/#findComment-11104522
1 minute ago, Almostbauws said:
sorry i also should have stated it was uk, I have also had a quick search of amazon and the nova seems to be the best bet, think ive answered my own question im ngl :/
https://linustechtips.com/topic/902396-smallest-atx-case/#findComment-11104531
Yes, bitfenix nova is the cheapest on pcpartpicker too:
https://uk.pcpartpicker.com/product/hJM323/bitfenix-case-bfxnov100kkxskrp
https://linustechtips.com/topic/902396-smallest-atx-case/#findComment-11104537
I've actualy been looking for the same thing to build an old PC for use in my workshop.
If u have a low prifle cpu cooler(< 120mm height) or AIO, this is the best cheap small ATX case u can get.
RIOTORO - CR1080
It costs around £60.
Nothing else comes close to its compact size for the price, the only other ones i've found are around the £100 mark and are the:
LianLi PC-A05FNB ~£109
and
Raijintech Thetis ~£85
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/902396-smallest-atx-case/#findComment-11104585
RIOTORO - CR1088*
Small note to add, the 1080 was discontinued and replaced with the 1088 (almost the exact same case) :) Highly recommended for being the smallest case ATM
https://linustechtips.com/topic/902396-smallest-atx-case/#findComment-11107647
