Gap in air cooler
Go to solution Solved by NMS,
Nothing is wrong here. If you wish however to improve your airflow a bit and direct it into the heatsink more, I'd use a fan rated for radiators (I forgot the bearing type), but basically a fan with small gaps in between the frame, lower blade count, and just larger blades overall.
Fans like that have a more one-way direct flow and not cone-shaped.
That's what I'm currently using. That gap between the heatsink and fan is pretty much allowing all the air to escape without passing through the heatsink. Does that mean I'm doing something wrong? It's not the stock fan.
Desktop benching:
https://linustechtips.com/topic/901671-gap-in-air-cooler/
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11097871
@Jade @NMS Just to add that the fan is pushing air towards the heatsink, rather than pulling away. The reason why I'm asking is that the stock fan is thinner than this one so it sits closer to the heatsink
Desktop benching:
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11097878
In the end, nothing to worry about at all. The only difference in your case might be a single degree difference. If amount of air pushed through per certain period is the same as with the stock one.
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11097888
The thing is that the leaked air is blowing so hard paper pinned on the bulletin board behind my monitor is waving around....
Desktop benching:
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11097906
This is normal and the gap will vary depending on the cooler. Sealing the gap with tape can improve performance but the difference is generally smaller with less restrictive coolers. For a rad with mid to high fpi or a dense heatsink, this can mean ~2-3c lower load temps. For a heatsink like the Hyper 212 with medium fin density, the difference is probably <1c.
Chances are that this is caused by airflow from someplace other than the gap.
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11097909
The CPU fan is one of two fans I have in the PC. The other is a weak 90mm case fan so I suspect the CPU cooler fan to be the culprit
Desktop benching:
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11097934
Yeah but that's not necessarily from the gap.
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11097936
There's flaw in that last part. Even thinner fan with same frame size would be as far from heatsink. Purely because of the way heatsink is designed. If stock would be smaller, then it might be closer to heatsink.
Other thing is how well it cools. If current cools better, I see no issue. Third would be airflow waving stuff outside the case. This would require side panel to be open for one and case being right next to thing it waves. And if "escaping" air still manages to do it, fan is far from weak. Heatsinks are designed in way where fins don't really block any airflow. As most of the air goes through and some escapes, that escaping maybe 25% would need to come from iPPC or Delta fan.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11099167
If it really bothers you then tape it up. You should get an intake case fan and put your side cover on so you don't blow papers around.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/901671-gap-in-air-cooler/#findComment-11100929
