Best Power Meter?
Solved by dalekphalm,
Just now, a.ron.a said:i just wanted to know if someone could recommend me a good power meter, a budget one would be nice (30$ or lower, or just one thats over but works well)
When you say "power meter", are you looking for an outlet power measurement meter, that measures current power readings on a particular load?
If so, the "Kill-a-watt" meters are probably the most popular among computer folks:
Their standard entry level model is around $20 USD
Share
Followers
4
