Yes its possible, yes its been done, it is alot of work. I'm fairly sure the engine should bolt into the mustang k-member providing you have a GT car, the length will get you the most. Its been done a few times, you dont really gain much in the way performance wise honestly unless you are comparing stock engines to stock engines. Cooling and accessory drive clearances will be an issue.
There was a killer build thread on theturboforums 5+ years ago and i believe on modmotormustangs (maybe corral.net) on a couple of people doing the V10 swap into them.
https://linustechtips.com/topic/897856-engine-swap/page/2/#findComment-11081240
On 2/24/2018 at 9:20 PM, dizmo said:
Seems like a very stupid idea :P As others have said anything is possible but....why? You'd get more performance out of a V8.
It would be awesome to have that v10 sound. Stupid almost always equals fun in my book;), but other than that idk why:D
https://linustechtips.com/topic/897856-engine-swap/page/2/#findComment-11106352
Or just buy the V8 and get a good exhaust :P I doubt a truck engine sounds that good anyway.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/897856-engine-swap/page/2/#findComment-11106369
