Posted February 16, 2018 im not sure which one to go for if i want to play GTA on v high in 1080p Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2018 Any GTX 1060 would run GTA and Fortnite on ultra 1080p Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2018 6GB 1060 ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2018 I have a gtx 970 in one of my rigs and a gtx 1060 6gb in another. Both are able to handle gta 5 and fortnite at ultra settings. For a CONSTANT 60fps (with no dips below the magical 60fps), get a gtx 1070, but if you can sacrifice some anti aliasing and you are okay with some dips, go for the gtx 1060. I recommend getting a strix over fe because fans stay off when not at load. Also, gtx 1060 can also be bought at a reasonable price while the price of the 1070 has skyrocketed in the last little while. CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2018 last year I build a gaming rig for a friend with a 6GB GTX 1060 and it can definitely play any AA titles on high/ultra 1080p 60Hz. I would not recommend FE versions unless you later on want to watercool, as most water blocks seems to fit universally for fe versions. The fan noise, or lack there of, is much better on manufacturer versions like the Strix and other similar cards - ie. better cooling, lower noise and/or higher oc. My Gaming PC: 27833 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 17, 2018 for GTA 5, you WILL have to learn how to use settings. Everything on Ultra, does NOT work if you need 60 fps at all times ;-) Know someone with an overclocked titan X (pascal), he can get GTA 5 down to 22 fps. Full HD @ max settings. Or he can get it to 92 fps in 4k. Just using the ingame settings. If you need ULTRA settings, then you want more than a 1060. And you NEVER want a Founders. Quite bad cooling, Loud etc. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
