So I accidentally bought a single stick of 8gb 1866 vengeance ram and never bothered to correct the setting in bios ( @ 1333 I believe ) before I installed windows, now when I go back to bios and try to change it the computer errors and automatically switches back. Unless I changed the wrong memory setting, i think it said d or v ram ( I can only make basic sense of the bios settings in mit ).
Any work around for this, can I run 1866 on a single channel? Thanks
8320 @ 4.3ghz l Gigabyte 970a Ud3 l Hyper 212 Evo l R9 290 l 8gb RAM 1866 Vengeance l 1tb WD Black l 120gb Samsung Evo SSD l HX750 Gold PSU l 500d Arctic Case l Windows 8 OS l K65 and Blackwidow Keyboard l M65 and DeathAdder 2013 l Qck Steelseries l 24in Vizio Monitor 1080p
https://linustechtips.com/topic/89679-changing-memory-speed-cant-boot/
Oh, good question it's a Giga 970a UD3, it has enough slots for 32gb memory, I assume it does that coupled with the fact that it let me switch to 1866 ( was x 20 i believe ) in the bios, although it never took.
Gigabyte GA-970A-UD3 motherboard....hmm...
What CPU are you using?
Yes, DRAM = system memory (RAM).
For 1866MHz, you will need to adjust the memory timings according to the listed / advertised values...if your motherboard does not detect the "XMP" settings.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
fx 8320 and I'm going to try again right now. It had a value multiplier I had to crank up to get it to 1866 and it wasn't automatically detected. I'm stumped.
