I have an idea, a Element Q size case, with a slim ODD in place of the reg. ODD & the front IO bay is a 3.5 right??? Just make that where you can place any 3.5 io panel in...  Then modify for a double slot gpu...
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/896414-case-udea-would-it-work/
ODD bays are 5.25
Just lose that bay altogether and use it for SSDs.
https://linustechtips.com/topic/896414-case-udea-would-it-work/#findComment-11044265
https://linustechtips.com/topic/896414-case-udea-would-it-work/#findComment-11044269
I want it to be 5.12 x 8.66 x 13 inch
https://linustechtips.com/topic/896414-case-udea-would-it-work/#findComment-11044509
10 hours ago, RorzNZ said:
Depends on whether you can find a suitable motherboard.
Really, I want a dual slot GPU in it, would widening it or putting space below the MB be better???
https://linustechtips.com/topic/896414-case-udea-would-it-work/#findComment-11046407
3 minutes ago, RorzNZ said:
You need a mini-ITX that supports SLI . . :(. Might have to see if you can find the smallest m-ATX case !!
Not 2 GPUs, a dual slot GPU * card that takes up 2 slots on the backplate...
https://linustechtips.com/topic/896414-case-udea-would-it-work/#findComment-11046479
4 minutes ago, RorzNZ said:
oh well just cut the case no problem
I meant if I changed it in protocase...
https://linustechtips.com/topic/896414-case-udea-would-it-work/#findComment-11046495
