So the problem with my wifi's speed is that it droppped from nearly 20MB/s to 5-7.5 MB/s(these speeds came from steam, but on speedtest.net it is around 65MB/s as it was before).
The only have changed that my brother got a pc and he connected it via a cable to the router.
My network car-Tp-Link Archer T6E
Os-Win 10 (newest update)
router-CBN Ch7465CE
https://linustechtips.com/topic/895213-wi-fis-speed-decrease/
Steam is not a great place to measure internet speed due to so much traffic on its network, if ur getting 65mb on speedtest.net then all is ok with your internet.
The only time your brothers PC will affect internet speed is if hes using a lot of bandwith streaming or gaming for example.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/895213-wi-fis-speed-decrease/#findComment-11031793
router-CBN Ch7465CE
Internet speed is measured generally in Mbps (Megabit per second), Steam shows it has MB/s (Megabyte per second). 8 bits per byte. 65 Mbps on Speed test is just over 8 Megabytes per second. So your getting the speeds your suppose to get.
https://linustechtips.com/topic/895213-wi-fis-speed-decrease/#findComment-11031819
okay, i see the mistake i mdae here, but it doesn't change the fact that y speed droped a lot
https://linustechtips.com/topic/895213-wi-fis-speed-decrease/#findComment-11031826
3 minutes ago, Gamman said:
i pay for the same package, no changes were made to my ISP contract, so it should stay same.
Well according to Speed test you get 65Mbps, correct? If that is what you pay for, then your getting the correct speeds in steam. Steam displays data as Megabytes per second. 65/8=8.125 Megabytes per second. If your getting 5-7 Megabytes per second in steam, then your getting about what you pay for.
Also no, just because you pay for a certain package doesn't mean you get the speed all the time. So ISP's are over subbed, some ISPs like mine, give us 20% more than what we pay for. Also, the server your connected to, might not be able to deliver max speeds due to congestion. There is a shit load that can affect what speeds you get. With out knowing what speed package you technically pay for, I couldn't say if there is even a problem or not. Because according to your first post, your golden. Also, steam servers are shit most of the time. I never get fast speeds downloading from them, most likely due to congestion. This is the reason they always die during the steam summer sale.
https://linustechtips.com/topic/895213-wi-fis-speed-decrease/#findComment-11031841
I guess i'll talk to my ISP and try to figure this out, but i have to thank you for your efforts in helping me.
https://linustechtips.com/topic/895213-wi-fis-speed-decrease/#findComment-11031860
You say your brother is connected via ethernet cable, does this mean you are connected wirelessly?
Wireless connections can often be slower than wired connections due to interference from other devices or walls and even other wireless networks.
Try getting a program called insidder and seeing whats the best wireless channel for u.
Internet Speed.....
https://linustechtips.com/topic/895213-wi-fis-speed-decrease/#findComment-11031880
