Difference between these fans?
Hi!
Whats the differenc Between Bitfenix Spectre PWM Led and Bitfenix Spectre Pro Led?
Whats the difference?
why are not the other one "pro"?
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/89447-difference-between-these-fans/
The Pro has a higher CFM
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
Bitfenix do not have the best fans, try corsair if you do not like the look of noctua.
As for the fans the pro is slightly quieter and has slightly higher airflow however I think airflow is not really a factor with those two.
"If you do not take your failures seriously you will continue to fail"
spectre_pro_pwm_specs.pngzz
what ? there is no Spectre "pro" PWM fans?, i thought there only was spectre PWM?
EDIT- it have no Leds:(
There is a wide range of Spectre fans.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
aha thx guys..
yes but Bitfenix what i have seen looks better and have stronger leds..
So how much better is spectre Pro led then Spectre PWM led?, is it a huge increase?
Not particularly but if you have the extra money i would get them.
