What are the O-Rings that best decreases the sound of the keyboard but barely decrease how hard to press and how far you can press.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/894333-o-ring-silencers/
well, you would need some soft O-rings for that. basically 40-50 Shore-A would be the most silent. usually those rings do take up about 1.5mm of your keytravel tough.
https://linustechtips.com/topic/894333-o-ring-silencers/#findComment-11023485
Mind sending a link? Also are there any ones that are less quiet but have less key travel?
My Rig
 Peripherals
https://linustechtips.com/topic/894333-o-ring-silencers/#findComment-11023528
I used 3/16th ID 5/16th OD EPDM o-rings I bought from my local seal supplier.
They reduce key travel by under 0.5mm when depressing adjacent keys with and without an o-ring, on my logitech G610 with cherry brown switches. Cost me $25NZ including same day shipping to my door.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
https://linustechtips.com/topic/894333-o-ring-silencers/#findComment-11023550
43 minutes ago, MatsNorway said:
You want one of these
http://www.wasdkeyboards.com/index.php/products/keyboard-accessories/cherry-mx-rubber-o-ring-switch-dampeners-125pcs.html
I have em and they work but it is not that impressive.
$15 for that? You can buy an entire bag for less than $1 on ebay... they are all pretty much the same.
https://linustechtips.com/topic/894333-o-ring-silencers/#findComment-11023564
Sure, if you can find the dimension and correct shore. I can take measurements at home. Ebay quality is not necessarily the same quality (life expectancy) but that is fine.
edit: same but from ebay, a tiny bit cheaper. : https://www.ebay.com/itm/Cherry-MX-Keycap-Rubber-O-Ring-Switch-Dampeners-40A-R-Blue-125pcs/122355079710?hash=item1c7cee5a1e:g:e~UAAOSw3mpXGsUk
https://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=40A-R+o-ring&_sop=15
https://linustechtips.com/topic/894333-o-ring-silencers/#findComment-11023785
2 hours ago, MatsNorway said:
I have brown switches myself. O-rings works great.
Can you recommend any specific O-rings?
My Rig
 Peripherals
https://linustechtips.com/topic/894333-o-ring-silencers/#findComment-11027365
okay heres where it may come in handy
so you love the feel of the MX blues but your dorm buddy hates it when you type on it at night if you get O rings you get the same feel but make the switch quieter so your room mate doesn't die of sleep deprivation lol.
Ex frequent user here, still check in here occasionally. I stopped being a weeb in 2018 lol
For a reply please quote or  @Eduard the weeb me :D
Xayah Main in Lol, trying to learn Drums and guitar. Know how to film do photography, can do basic video editing
https://linustechtips.com/topic/894333-o-ring-silencers/#findComment-11027993
