Does it overheat?
Welcome to the forum!
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/894136-pc-help/#findComment-11022838
You should post on the correct forum section and gather more information towards what happens, though if I had to guess there is something wrong with the memory configuration.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/894136-pc-help/#findComment-11022951
14 hours ago, Tomwalden23 said:
MY  Pc will get power turn on but then after 15 seconds if will restart can anyone help ?
I was also facing the same issue about my laptop because of heat. After I clean my laptop and fan than its never got heat and working good. I will also suggest you check your PC also getting heat and fan working correctly.
https://linustechtips.com/topic/894136-pc-help/#findComment-11023540
