Hello LTT -
I have no use of my gaming rig anymore, as I simply do not have the time to game and personally don't find it very fun anymore and/or a good dedication of time. I have since moved over to Linux, further isolating myself from Steam and the likes of online gaming. I've started to compile a list of (used) parts for a small, quiet, and practical PC for my needs (the only major tasks are downloading torrents and general online media consumption).
I have an idea for low cost, power sipping build. No need for NVMe drives or that sort, I have my SATA drives.
My ideas:
Intel i5 2400s
Some Micro ATX or Mini ITX LGA 1155 Motherboard, maybe a used OEM board
Don't really need a GPU (tho I have a 750ti if need be)
8GB DDR3 - in inventory
275GB 2.5" SSD - in inventory
500GB 3.5" HDD for storage - in inventory
SFX PSU (?)
A small, affordable, and practical case, preferably console or cube size (but it must hold a 5.25 inch drive for my DVD/R. yes, I'm an old fashioned type of guy)
Any ideas, suggestions, and comments are welcome! (no hate tho pls)
EDIT I: I found the Cooler Master 130 case. Can hold 3.5" HDDs and has enough room for my 275GB 2.5" SSD. Will update on part discovery
EDIT II: Not many LGA 1155 OEM MOBOs have USB 3.0 headers :/  I'll have to look for a case with USB 2.0. I'm fine with it anyways, not too big of a factor
EDIT III: Gonna bite the bullet and go Ivy bridge. CPUs and MOBOs aren't all that different in price, plus I won't have to go through adapter hell. Though some motherboards (Dell 7010 SFF) might have size and thread incompatibilities with the Cooler Master 130 I chose, but I'm gonna double and then triple check just to make sure.
https://linustechtips.com/topic/893683-low-power-media-pc/
Case:
https://pcpartpicker.com/product/T3rG3C/cooler-master-case-nse200kkn1 ?
It's a Micro ATX cube style one.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/893683-low-power-media-pc/#findComment-11015813
Not a whole lot of SSF cases have support for 5.25" drives. You should be able to get by without a GPU, Intel HD should be enough.
The Corsair Obsidian 250D has support for one 5.25" drive: http://www.corsair.com/en-us/obsidian-series-250d-mini-itx-pc-case
Another thing you may want to do is get more HDDs, or a bigger one.
https://linustechtips.com/topic/893683-low-power-media-pc/#findComment-11015817
