2 minutes ago, Canada EH said:
Are there slim rad fans available which dont skimp on cfm's?
if you don't care how loud it is then yeah there's plenty.
run slim fans at 100% speed and they'll move as much air as a thicker fan at low speeds.
https://linustechtips.com/topic/893556-slim-radiator-fan/#findComment-11014426
There's the Prolimatech Vortex12. It claims 54CFM, but don't expect that to be quiet.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/893556-slim-radiator-fan/#findComment-11014434
Just now, Canada EH said:
I care about noise, to the extent I dont want to spend more then I have to.
if noise is a concern you should run a standard air cooler on the cpu as it only needs a single fan rather than the rad which needs 3 and a pump.
should reduce the noise greatly.
https://linustechtips.com/topic/893556-slim-radiator-fan/#findComment-11014437
100cfm's come in at ~40db
Pcpartspicker is a good source to find noise levels, cfm and rpm, looking at it now. Still want slim though
https://linustechtips.com/topic/893556-slim-radiator-fan/#findComment-11014439
1 minute ago, Canada EH said:
just looking at the list on pcpartspicker
probably coorelated to rpm as well right.
18db but 81cfm and 1600rpm looks decent
averages are 30-35db to 45db
x3 because there are 3 fans not one
so you want to use a 360mm radiator , you want the fan to be smaller than normal , you want them to be quieter than normal , you want them to run slower than normal , and then want to the cpu to be cooler than normal.
just making sure I got all this correct before I recommend a stock plastic intel heatsink.
https://linustechtips.com/topic/893556-slim-radiator-fan/#findComment-11014470
https://linustechtips.com/topic/893556-slim-radiator-fan/#findComment-11016087
