144hz 1440 montior. Questions and suggestions?
scanjet1000
These are a few I've been looking at. https://www.newegg.com/global/uk/Product/Product.aspx?item=N82E16824236660 https://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16824011082
Pretty much I want a 1440p monitor but I want it to be good for comp gaming as well. Csgo and stuff like that. So my questions are. Will they be 144hz all the time or is that overclocked or something like that? Can I turn them down to 1080p if my pc can't handle the 1440p on a game? Can I use them with a 60hz secondary monitor?
How do I find the input lag so I can decide which one will be a better purchase?
Thanks
https://uk.pcpartpicker.com/list/YC42KZ
Thanks
basically 144hz for serious gaming and only if your pc can get 144 fps or above at all times and 1440 if u want it to look nice.
Thanks
If it says 144hz on the specs or description it will run at 144hz all the time. Seeing as you have a 1080 from experience I can tell you that you can get above 144hz a majority of the time at 1440p in most games. Yes you can hook up any combination of monitors you want, and those monitors look really similar. I would go for the asus one as it has a higher refresh rate.
 BUT I got this monitor over any other of the monitors because it is a 144hz 1080p curved ultrawide for a freaking amazing price. You will definitely notice pixels when writing word documents and stuff like that but not when you are gaming. It really is a great experience and i couldn't be happier with it. https://www.amazon.com/LG-34UC79G-B-34-Inch-21-UltraWide/dp/B01LW5CGIS/ref=sr_1_3?ie=UTF8&qid=1517774732&sr=8-3&keywords=lg+ultrawide+curved+gaming+monitor&dpID=51DuJ0LvkqL&preST=_SY300_QL70_&dpSrc=srch
Hope I helped. Also the pixels wont bother you after a while.
Build:
Intel Core I7 6700k (clocked to 4.6ghz)
Patriot Viper 3000mhz ddr4
ASUS maximus 8 hero (I hate this mobo)
Evga gtx 1080 superclocked
250GB Samsung 850 evo
2tb WD Black 7200rpm
Ek watercooling kit a240g with 360 expansion pack
Primochill Vue Red fluid
Corsair Graphite 600t (white)
You thought "Gee, Donald Trump sure has a great build!"
@DarthSmartt
Hi, thanks for the response. I'm pretty set on a 1440p monitor.
Another question. The asus monitor has a 4ms response time and the other one has a 1ms.
Any idea how big of a difference this is?
34 minutes ago, scanjet1000 said:
@DarthSmartt
4-1=3 quick maffs
On 2/4/2018 at 6:14 PM, scanjet1000 said:
@FiveNine Umm that didn't really help at all. :P
On 2/4/2018 at 4:59 PM, scanjet1000 said:
@DarthSmartt
bro no diffrence unless your a pro honestly.
You can also check the aoc ag271qg, which should be sharing the same panel as the two you mentioned. It can be oc to 165Hz like the predator (didn't check if the Asus is the same). I got mine to 165Hz with no problem. The aoc is usually cheaper but has probably the worst osd between the three.
For the input lag I found a big comparison a while ago before buying my monitor but I can't find it anymore. I remember monitor with a very quick response time gtg being actually quite worst than others when comparing input lag. In my opinion even input lag aren't noticeable unless professional gamer, but this is the number you should check instead of the grey to grey response time
Latest build: MyPC Liquid Time
