Speedfan refuses to change the RPM of my noisy chassis fan
Solved by sanosuke001,
http://pinoutguide.com/Motherboard/mb_pwm_fan_pinout.shtml
If the digital control isn't connected that'd be my guess as to why you can't control it. Connect it to a different fan header on your motherboard if possible. If not, get a fan controller; you can get pci slot ones, 5.25" bay ones, ones that you just put inside the case and set once, etc.
Featured Topics
Elarion ·
Posted in Troubleshooting1 -
Sjokk ·
Posted in Graphics Cards1 -
2
AccDossNumber15 ·
Posted in Cases and Mods2 -
Splatacake ·
Posted in Peripherals1 -
2
6
play_circle_filled
Latest From Linus Tech Tips:
iPhones Are Undeleting Nudes?? - WAN Show May 17, 2024
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
