I know I know, asking for mac advice....
The SSD on my early 2015 macbook air 11" has died, and I need to replace it. Apple wants $400 US to replace it, I found this drive on amazon that I think should work. However I need to know it will work, as I plan on having somebody bring it all the way to Bolivia for me.
Drive:
https://www.amazon.com/gp/aw/d/B00TAW47O4#Ask
Macbook Air 11" model number A1465
Thank you in advance
https://linustechtips.com/topic/891424-macbook-air-replacement-drive/
It will work.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
It looks like it should work, but the OWC units definitely will work but they only appear to go as low as 256GB and are quite expensive.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
It's the same part number as the one listed with iFixit, and it's the right 12+16 pin connector. So as long as the seller is honest, then it's compatible.
PSU Tier List | CoC
