My desk has the elevated section on the right side against a wall. I cannot see into my PC, and I also don't like the look of my case very much anyways. It is an NZXT Phantom 240.
So since I am getting a new case and I want to see into the case, I thought that inverted cases might be a good idea.
If anyone asks why inverse here are some reasons:
You can see into the case if it is against a right side wall.
The graphics card heatsink will be facing upwards instead of downwards, so you can see the goods without having to vertical mount it and restrict airflow.
Anyways, I need a case that has basic liquid cooling options. I have a 120mm AIO on my cpu and I am planning on getting another 120mm AIO for my gpu or liquid cooling all of it with one of the kits from ekwb. Here is one case I found: https://www.amazon.com/Corsair-Carbide-Clear-Inverse-Tower/dp/B016IAM7D8/ref=sr_1_1?ie=UTF8&qid=1517245297&sr=8-1&keywords=600c
I would love it if the case was white also. But its not a limit. Also I would prefer it to be under 150 dollars, less if possible.
Here is my build: Motherboard: Asus Z170-k Processor: Intel Core i7-6700k Gpu: ZOtac GTX 1080 Amp edition
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/891105-inverted-atx-cases/
BeQuiet!'s darkbase series cases can invert the motherboard tray, so you can adjust the layout as you please.
personally I like the looks of the carbide you posted better tough!
https://linustechtips.com/topic/891105-inverted-atx-cases/#findComment-10989044
I've got that Corsair case. I find it ok, if a bit weird putting things in upside down... just remember it is acrylic window not tempered glass.
https://linustechtips.com/topic/891105-inverted-atx-cases/#findComment-10989067
Riotoro CR1088
https://www.newegg.com/Product/Product.aspx?Item=9SIA2F86SX2133&cm_re=CR1088-_-11-241-005-_-Product
Based off the successful CR1080, which you can see builds of here
https://linustechtips.com/topic/891105-inverted-atx-cases/#findComment-10989123
5 minutes ago, TVwazhere said:
I never knew there was a product after the CR1080. I've looked at that one before and liked it, but not enough to buy it. Let me check out the newer one.
https://linustechtips.com/topic/891105-inverted-atx-cases/#findComment-10989152
It's very similar, mostly the front panel changed a bit. The interior is exactly the same from what I can tell.
https://linustechtips.com/topic/891105-inverted-atx-cases/#findComment-10989292
