Hey,
I currently have my new i7 8700k overclocked to 4.5GHz @1.29V, doesn't the voltage sound quite high for this clock?
Anyways, when dropping voltage to 1.28V, threads 7 and 8 get errors in Prime95 Small FFT, same happens when going to 4.6GHz regardless of what voltage I set, and at 4.8GHz threads 3 and 4 also start failing. Is this one core just that much worse than the others? Am I just unlucky and received a badly overclocking CPU or is there maybe something else that could be causing this?
I ran 10 hours of Prime95 Blend with 4.5GHz @1.29V without any errors.
The specs of the new PC:
  • MSI Z370 Gaming M5
  • Intel i7 8700k
  • Cryorig H7 cooler with 2 fans
  • MSI GTX 1080Ti
  • 4x8Gb Kingston HyperX Fury @2400MHz
https://linustechtips.com/topic/890394-i7-8700k-overclocking-help-needed/
  • Intel i7 8700k
  • MSI GTX 1080Ti
Cooler? Its the most important part. Temperatures determine voltage requirements.
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
either u got very unlucky with ur cpu or ur motherboard's the problem, also what are the temps
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
My cooler is the Cryorig H7, I realize that it is not one of the very best coolers but certainly one of the best ones of the smaller air coolers. Temps seem fine to me, getting to high 80's (celsius) when doing Prime95. Temps are 35-50 when browsing the internet or watching stream or something like that, 60-70 when gaming.
try 4.7@ 1.3v and with an avx offset of -2, temps are fine so i'm thinking it's just silicon lottery, also make sure there's a airflow on the vrm
Ok I tried your settings and got no errors in 8 minutes of Prime95 Small FFT (I usually get errors way before 8 mins). Thread 1 was however not doing anything, and also shows only 85% max utilization in HWMonitor. The clock also got throttled to 4.5GHz during the stress test. Temps were hitting 100 celsius on some of the cores too... So maybe it is a heat issue after all. I started wondering about my thermal paste application, I remember there being some quirks when installing the cooler, so might have fucked the paste. Maybe I should just try to reapply the paste and see what happens...
Uploaded an image from after the test if that would give some extra info.
After some reading I really doubt it is the thermal paste either... probably just the cooler is not good enough to overclock this CPU. I'll probably end up buying some AIO water cooling thingy in a month or so to replace this one, for now I'll stay with the factory 4.7GHz single, 4.4GHz all cores boost.
it's the heatsink, u should try optimizing the voltage, the absolute max i'd run on a h7 is 1.25v, ur running 1.315. Whatever your cpu will run on 1.25v is the max oc, keep in mind nothing you do realistically will be as stressful as p95, but u still don't want 90+C even during prime.
Well, the more cooling power your cooler has the more clock you get with lower voltage. You safe 4% power every 10°C.
The H7 is rated with a TDP of 140w. Alot of the bigger Twin Tower coolers are rate for a TDP of ~240w.
I'm now running it at 4.4GHz @1.23V and it seems stable. Temps stay under 85 even after a couple hours of prime95. Guess it's time to get a better cooler then. Any recommendations? My case is the Fractal Design Meshify C, it can't fit many of the bulkier twin tower air heatsinks, so I was thinking about some AIO water cooling solution that I should be able to mount to the front.
noctua u12 minimum, i recommend d15 if u dont mind ugly, it performs even better than the AIOs, but if u want AIO, just get a big one, i recommend h100i or 115i ,most overestimate how well they do, but they are more quiet depends on how u set it up. just need a case fan/airflow on the vrm (vrm cooling usually isn't a problem for aircoolers)
that case will be fine. a 360mm rad fits in the front. I would say
Corsair H150i Pro (little bit expansive)
or
Alphacool Eisbaer 360
8700k does 4.7ghz all core with default voltage settings.  Turn MCE on.
And pretty much anything can cool an 8700k with 1.4v if you are delidded.
Better cooler wont fix your problem.
1.4v 5.3ghz AVX using an h100i that's years old getting avg temps in stress testing like Large data set OCCT of 54C.
The gap between the IHS and cpu is to large from the glue they use on the IHS.  No gap to the smallest gap with liquid metal is key for 20-30C drop in temps.
CPU:                       Motherboard:                Graphics:                                 Ram:                            Screen:
i9-13900KS   Asus z790 HERO      ASUS TUF 4090 OC    GSkill 7600 DDR5       ASUS 48" OLED 138hz
Delid time I would say!..
Built a few i7 8700k systems and yours seems to be a prime candidate for it my friend.
I would suspect that would take care of your issues.
I'm running a simple nzxt x42 v2 at 5g overclock max temps are 72ish
