Asus AI suite 3 (Fan Controller) no longer opens
I really like Asus, but man, most of their software are pretty buggy ... I went through this a long time ago, and this is how I manage to make it work.
1.- Uninstall current version from Control Panel (typical uninstall, don't use the Add or Remove Programs from Windows 10, use the one uninstall from Control Panel)
2.- Go into the folder where AI Suite was installed and make sure to delete every folder from there.
3.- Run CCleaner and clean registry
4.- Turn off PC and unplug power chord for 30 seconds and turn back on
5.- Run AI SUITE 3 CLEANER
6.- Restart PC
7.- Download AI SUITE 3 VERSION 3.00.10 & 3.00.13 (Its a Beta version but is WAY more stable than others)
8.- On the downloaded file, right click on it and select Properties
9 .- At the very bottom, in the Security section, mark the checkbox that says "Unblock"
10.- Extract content and install.
11.- Turn off PC by using Alt + f4 then Shut Down.
12.- Turn back on and enjoy AI Suite
13.- Have a beer after all the trouble.
I hope it helps
