Hey Almighty Internet and PC Maters
My Motherboard does not not detecting my GPU.
I built this PC 3 days ago, and I was using my CPU's Integrated graphics and everything works perfectly fine.
I got my GTX1070 yesterday, but nothing has changed after I inserted the GPU on my motherboard .......
These are the lists of things I did to solve this problem:
I updated/renewed the BIOS
I cleared the CMOS
I reset everything in Bios about PCIE priority
I checked the GPU carefully
I enabled the CPU graphics in device manager and restarted.
I downloaded and installed the GeForce Experience and NVIDIA1070 drive
BUT None of them solved the problem.
So I am begging for help :(
Any suggestion is appreciated
Set up details:
i5-7500
Motherboard: B250M-DS3H
EVGA 500W
MSI GTX1070 ARMOR 8G OC
One Ballistix 8G RAM 2666MT/S
120G SSD
1TB HardDrive
https://linustechtips.com/topic/889273-help-motherboard-does-not-detecting-gpu/
You plugged the monitor into the graphics card and you're at least getting a picture though I'm assuming?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
Welcome to the Community!
Just in case, make sure you plugged your monitor into your graphics card :)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
PCIE Power plugged in?
what PSU is that EVGA 500W? They make some 500W garbage ones
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
I plugged the monitor into the gpu nothing shows up :(
Yes PCIE power was plugged in. My PSU is EVGA 500 W1, 80+ WHITE 500W, 3 Year Warranty, Power Supply 100-W1-0500-KR, Black
13 hours ago, RAM555789 said:
Could you perhaps take a picture of it running in your rig, I assuming the fans spin up and all since your saying its just not being detected, also try resitting the GPU?
GPU does not move at all. It drives me crazy.
I can't really help you in GPU advice, but - if you can return that PSU.
Full Specs
Helios EVO (Main):
Delta - Laptop
Did you plug in the 8-pin connector! Probably yes. I had the same problem with this and I just switched from HDMI to Displayport and everything worked, but I think its a problem with power. I think that your graphics card is defective. I would contact the manufacturer and ask for a replacement! Stay away from EVGA PSU's they aren't great! I would recommend a Corsair PSU next time
