So i recently i have started an issue and need help diagnosing an issue, i think it is screentear but not 100% sure i have a 60hz monitor and am wondering if a 144hz would fix the issue also my pc is well capable of running csgo also ask any questions necessary also for some relive doesnt show it but the screen sort of tears and there are noticeable lines when turning  around
RX 480 nitro 4gb
i5 6500
8gb ddr4
heres a link to a vid of it (pay attention to fps)
and the lines are similiar to the ones in the pic below
any advice helps
https://linustechtips.com/topic/889171-help-diagonising-an-issue/
~Moved to Displays
Screen tears are something we all learn to live with. There is a solution with vSync and Fast Sync, which eliminate them but introduce some input lag (a lot in the case of traditional vsync). You don't want that as a CS:GO player so screen tears it is.
Screen tears are less apparent with higher refresh rate monitors, yes, and also if you're pushing through a lot of fps.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Just now, AH4 said:
so a 144hz display would also fix the wierd fps drops
No. It will make them less noticeable if the display has GSYNC or FreeSync.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
Wait so turning on vsync wil make it run wurs? you know if you monitor runs at 60HRz it will only show 60 img a sec. so when you trun on vsync your gpu just renders a max of 60 imgs a sex and not more. and yes its wil "dip" vaster but than again thats maby 2 FPS with with vsync on you wil not notis a bit.
TLDR stop winging or turn on vsync
"i reject your reality and substitute my own"
          --- Workstion --- GamePc ---
"College great Dropout Engineering"
4 minutes ago, AH4 said:
ok i have just one last question are those fps drop due to tear
lets see your gpu takes 1MS to render the frame and your monitor takes 5MS to render(show) the fram. wen your gpu gets a jump to see 100MS (to render a frame)than back to 10MS your screen is stil rendering that first frame wen a ather frame is send by the gpu so its start rendering frame 2 en thats how you get "trarring" its alreding updating to the second img wen its not even done rending the first frame.
No its the ather wee around, tearing becas of dropt fps .
(i think LTT did a video on this cant vind it do)
I can barely see any screen tearing in that YouTube video of yours. Maybe I was too focus on where your character's crosshair is pointing, instead  of its surrounds. Do that and your screen tearing problem will magically go away.
