I am looking to spend about $500 on a mining rig. I currently have a 1060 I can use in the system. I would like the motherboard to support 3 GPUs minimum and do not care about mining specific capabilities unless they are the same cost. I am not willing to purchase from 3rd parties. I would prefer to use Amazon for the transactions. What motherboard, case, CPU and PSU should I buy? I am looking to spend about ~$200 on those parts so I can afford a second 1060 or an RX 580.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
https://linustechtips.com/topic/889169-building-hobbist-mining-rig/
Only $200 on all those parts? That's cutting it close, if not impossible.
Getting a cheap Intel Celeron and compatible ATX mobo will run up to around $100.
A sufficient psu will need to be 550w to 650w, if you plan on going with 3 1060s. Now going with 580s will require at least a 750w psu. Higher efficiency, the better. So the power supply will cost you around 70 - 100 bucks at least. That last amount you'll probably want to get some wood and nails from your local hardware store. Aluminum is recommended, but your budget won't allow for that. Do not use a case when mining with more than 1 gpu, unless it's an open-air case. And then you might want to get some Noctua iPPC fans to throw on top of the gpu's to exhaust the heat.
print "Hello World!" ("Hello World!")
I don't know where you have been (maybe A mushroom field somewhere in Narnia?) but you have about the same chance to get struck by lightning as you have to get gpus within that budget. The gpu market is in a bad state right now.
To answer your questions though, for a rig that small you can just use a normal psu and then get the cheapest motherboard and cpu that fit what you have stated above
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
Wow. I just bought a 1060 a few weeks ago for $300 and now they are going for $500. Jesus.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
A bit out of the way, yes.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
I figured from the part pricing I was seeing.
What rating should I shoot for?
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
AMD option: https://www.newegg.com/Product/Product.aspx?Item=N82E16813157616&cm_re=SOC-_-13-157-616-_-Product - $50
Intel option: https://www.newegg.com/Product/Product.aspx?Item=N82E16813157513 - $60
3 x 1x risers and some electrical tape ($30-ish)
an open box frame ($100?)
decent 500w-ish PSU to power any external connections (another $100?)
a 4GB stick of DDR3
and a 16GB USB drive (find one in the couch cushions)
zimzim-ala bim! cheapest 3-card (capable) mining rig on the planet. 330-ish bucks.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
