Want to order everything from Canadian retailers. Hopping to play battlefield 4 on high with playable fps and some other less demanding steam titles. Looking to save the $100 from a windows license and try out steam os as I'm only going to use the machine for gaming. I already have the case, its an Antec gx700 (got it on sale for $25!). This is all going to be on a single 24" monitor at 1080p.
-AMD fx6300
-Asus M5A87 AM3+ with usb3
-2x4gb dimms ddr3 1600 kingston predator (only $55)
- WD 500gb Caviar Blue
-Gigabyte 270x or gtx760 (760 is about $40 more when I was shopping around)
-Corsair 500w PSU
PC Part Picker:
http://ca.pcpartpicker.com/p/2kb5l
My main concern is if I should save a little more and go for the 760 or would the performance difference be fairly negligible? Any help is very much appreciated.
https://linustechtips.com/topic/88717-500-600-gaming-build/
760 is more powerful than 270x, but its pretty much your decision if you want to spend a little more and get a little better performance or youre fine with this...
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/88717-500-600-gaming-build/#findComment-1201131
https://linustechtips.com/topic/88717-500-600-gaming-build/#findComment-1202160
Which 270 do you think would have the lowest temps and over clock the best? Think I'll get a 270 and just over clock it to 270x speeds
Doesn't make much of a difference. They're all pretty similar.
https://linustechtips.com/topic/88717-500-600-gaming-build/#findComment-1202735
Thank you for the help I appreciate it :) If I can find a 7870 for cheap that is pretty much equivalent to the r9 270/x right? I'm seeing some for quite the bargain
Yeah, the 270 is pretty much just a 7870 rebrand.
https://linustechtips.com/topic/88717-500-600-gaming-build/#findComment-1205441
