Best minimalist mid-tower case for £/$100 or less?
Apepa
I'm not really a case person, so I have no idea what brands/models are the best for acoustics and airflow.
Basically looking for something with that Corsair Carbide/Define R5 sort of design where it just looks like a plain black box and has some soundproofing.
I don't want anything bigger than a mid-tower, as I do tend to move my rig a fair bit.
Needs to fit:
Full ATX PSU
Full ATX Mobo
1x 5.25 Optical drive
At least 2 x 3.5 HDDs
At least 2 x 2.5 SSDs
a Noctua U14S cooler (165mm)
And it definitely must not have any RGB, or side windows. As far as "build quality" goes, I can live without diamond-crusted power switches as long as the thing looks good, stays cool and doesn't make much noise.
Fractial Define R5 is What i would go for, I have it, it look great, and is really quiet, and nice build quality.
Though Define R6  is a little nicer.
Meshify C/S340
My life
As far as good performance, minimalist cases go, you can't go wrong with a Fractal Design Define R5
https://uk.pcpartpicker.com/product/sjX2FT/fractal-design-case-fdcadefr5bk
A good alternative is the Be Quiet! Pure Base 600
https://uk.pcpartpicker.com/product/PNTrxr/be-quiet-pure-base-600-atx-mid-tower-case-bg021
9 minutes ago, Himommies said:
Meshify C/S340
3 minutes ago, Damascus said:
Define r6 or define c
OP needs housing for a 5.25" drive
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Hmmm....very interesting that nobody has mentioned any Carbide ones so far.
The 600Q? The 400Q doesn't have any 5,25" drive spots. Most of the Carbide series is quite old
I honesly wouldn't care if it was 50 years old if it fulfilled my requirements. I mean interesting from the perspective that nobody can recommend them. It's a shame because I actually prefer the look of their cases.
R6 has one
Want to custom loop?  Ask me more if you are curious
45 minutes ago, Damascus said:
R6 has one
That was addressing your Define C recommendation
Computer Specs:
I just don't think the carbide aesthetic is what I'd call minimalistic
https://pcpartpicker.com/product/2WkD4D/corsair-case-300rwindowed
https://pcpartpicker.com/product/shtWGX/corsair-case-cc9011086ww
Though I suppose the 400C/Q does fit the description.
At first I thought that you didn't want a Window but here's a case I really like that has that minimalistic aesthetic and a full Window -
https://uk.pcpartpicker.com/product/2mQRsY/phanteks-enthoo-pro-m-tempered-glass-atx-mid-tower-case-ph-es515ptg_bk
Probably my favorite case and what I'd have if I had disposable income :P
Computer Specs:
Why do you want a 5.25" Drive? Seriously?
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
The FD Define R6 looks amazing to me, it's quite clean and has some cool features, but I guess the most important for you is the ODD cage.
1. Large DVD/BD collection
2. Backing up to HDD or flash is more expensive and less reliable
3. I use Data CDs in the car because they are (again) more reliable
4. I'm old.
