I was attracted to the typo in your Title there :P.
Generally all an external HDD enclosure is in a real HDD with a bit of PCB that turns the sata connections into a USB one. so as long as you keep the PCB as well it will be ok. but i fail to see a reason for doing it.
Quack 🦆
https://linustechtips.com/topic/88500-external-hard-drive/#findComment-1198692
Yes but it would increase the components to fail even more from drops. The outer shell is kinda the only protection a external hard drive has.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/88500-external-hard-drive/#findComment-1198693
So I'm build a new pc and I have a 1tb external hard drive for back up, and I was wondering if I take it out of its shell would it still work and communicate with it correctly. I think it Well just want to make sure.
Thanks
Why do you want to take it out of its shell? And, what "it" needs to work and communicate with the drive?
https://linustechtips.com/topic/88500-external-hard-drive/#findComment-1198695
Well if you take it out it wont have the connection (USB) anymore so you couldnt communicate anymore...
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/88500-external-hard-drive/#findComment-1198697
An eternal hard drive, that would be nice
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/88500-external-hard-drive/#findComment-1198700
Thanks
Well, this depends.
Some External HDDs have a different connector. While some do have a SATA->USB adapter built into the casing, others have the USB soldering directly onto the PCB replacing the SATA.
If your particular external HDD is the former (SATA->USB adapter on the casing), then yes, you can take it out and it work as an internal drive.
If it is the latter (USB soldered directly to PCB), then no, it will still need to use the USB to communicate with things.
It will work fine either way, but there's no point in taking the casing off if it's USB soldered to PCB.
For reference, I have only ever seen it be soldered to the PCB with USB 3.0 capable external Hard Drives. If it's USB 2.0, it's probably a SATA -> USB Adapter.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/88500-external-hard-drive/#findComment-1198730
