I recently bought a pair of HyperX Cloud Stingers and they are great but I've noticed a flaw in them and I want to find out if that's a con to the headset or that mine are faulty. So the problem I have is even when the mic is muted it works like normal when it comes to noises like my voice and everything not connected with the headset, but if my mic is muted and I try to play something through the headset at a moderate volume my friends can hear what I'm listening to on their end while I'm muted. I want to return them as fast as possible since I paid like 80 euro for them (prices are horrible in my country).
https://linustechtips.com/topic/884822-hyperx-cloud-stinger-sound-leak/
80 euro? wow that is so expensive.
Yep it must be fauly.
Try look at the new corsair HS50 while its a semi open but the sounds doesnt leak to the mic.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
The sad thing is we don't have corsair headsets here and anything close to this price point for me are the Arctis 3 which are 20 euro more. And maybe I should have said that the sound my friends hear is really faint and on discord, the way I set them up they can only hear sudden loud noises but still there is a flaw
Dont get the artic.
How about the cloud core? how much does it cost?
I had a similar problem, turned out it had something to do with the front jacks on my computer case when I plugged the headset into the back directly into the motherboard ports the problem went away. Maybe try plugging the headset into different ports would be my suggestion
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
Just tried the other ports I have on my PC and the issue still persists.
Actually, in the motherboard ports it seems to be really random the first couple of times I tried to see if there is some sound leak there was a lot and I tried muting the mic and unmuting it and now its better I mean the issue is still there but it isn't as loud as before
