URGENT! I need help!
Go to solution Solved by tj_314,
for your second exercise: To find an intersection between two curves means to find all points that belong to curve 1 and curve 2 at the same time. It basically means that you have to solve a system of equations. In your case the two equations are the parabolas you provided. From the second equation, you get y = x^2 + 2. you plug it into the first equation and you get -x^2 + 4x + x^2 + 2 - 2 = 0 which simplifies to 4x = 0 and therefore x = 0. There is only 1 intersection point at x = 0. now, you just calculate y value from any of your two equations. since we already know that y = x^2 + 2, we get y = 2. The intersection is at x=0, y=2.
Should it be 2x or 2x2 (squared)
5 members have voted
  1. 1. What should it be? Please only answer if you really know, no trolling.
So, tomorrow I have a Math test, and in my Guide, I cant figure out an exercise. Can you help me? Its Analytic Geometry. But I cant find it on a teachers book. I need to know if you need to square a number.
The exercise is about parable equations. The Directive too. The exercise is: y-2x-2=0 with focal poiunts beign (2,-2) However, I dont know if it should be 2x or 2x2? Mathematically in this case what should it be?
And in the second exercise, quote: Find the intersection between the parables -x2+4x+y-2=0 and x2-y+2=0? How would you solve that? Any info is appreciated.
TO A MOD: Please dont change it to another place, I need this to be seen by as many people as possible. Thank you.
https://linustechtips.com/topic/884419-urgent-i-need-help/
People see it equally either place, since they usually look at the side.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/884419-urgent-i-need-help/#findComment-10923752
3 minutes ago, Abyssal Radon said:
Ultimately your trying to figure out the points that the equation's intersects? Your wording is strange, anyway I can try and solve it and take a picture of my work. Assuming that would help, your doing a Analytical Geometry course in high school or college?
It looks like HS work I was doing this type of math in high school.
https://linustechtips.com/topic/884419-urgent-i-need-help/#findComment-10923767
I am translating directly from Spanish, I am sorry.
https://linustechtips.com/topic/884419-urgent-i-need-help/#findComment-10923779
High School
https://linustechtips.com/topic/884419-urgent-i-need-help/#findComment-10923781
I don't know if this will help but I found this. http://www.geteasysolution.com/y-2x-2=0 from me looking at the answer I think it's 2x. but I'm not 100%
https://linustechtips.com/topic/884419-urgent-i-need-help/#findComment-10923788
https://linustechtips.com/topic/884419-urgent-i-need-help/#findComment-10923867
Sorry but that's not how it works.
Moved to off-topic section
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/884419-urgent-i-need-help/#findComment-10923902
