Phanteks fan hub
Go to solution Solved by zombienerd,
I have a silverstone hub that uses SATA power, and the answer for mine is yes, I'd imagine the Phanteks is the same.  It uses the SATA power for extra 12v, but uses the PWM lines to control the actual speed.
Edit: I just looked at your link, and the hub seems to only have 3 pin headers for output.  So the answer is "maybe".  It depends on your motherboard's (or the hub's) ability to control speed of a 3 pin fan.
TL;DR of this one is this: do you still get PWM control over fans using this hub right here if you plug it into the SATA power header? Thinking about buying one to control two power hungry fans that will not run off a single header on my motherboard, as well as maybe a few others.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/884061-phanteks-fan-hub/
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
https://linustechtips.com/topic/884061-phanteks-fan-hub/#findComment-10919960
If you're interested, this is the Silverstone unit I use, which can control up to 8 4-pin PWM fans from one motherboard header + SATA power.
Silverstone 8 port PWM Fan Hub
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/884061-phanteks-fan-hub/#findComment-10919977
From what I remember of mine, it allowed you to use either PWM or just normal 3-pin control (I managed to kill it from too low of voltage running off a single motherboard header).
But as long as it works like you'd think it would (who knows how things actually work when it comes to tech lmao), I guess I'll go ahead and get one then crack it open and stuff it where my old one used to be since it's the same PCB from what I can recall.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/884061-phanteks-fan-hub/#findComment-10920050
Yes, you get PWM fan control, but theyre controlled through the normal Voltage, so any LED fans that you would use would flicker, get dim or not work at all in very low RPM modes. I've used it previously in my Blue Build, fortunately I kept the fan speeds up high enough where this wasnt an issue.
https://linustechtips.com/topic/884061-phanteks-fan-hub/#findComment-10921541
Not a problem for me anyways then since I won't be using LED fans. ?
I do appreciate the clarification though, it's been so long since I still had mine that I had forgotten just how it controlled them.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/884061-phanteks-fan-hub/#findComment-10922012
