Fractal Design Define R6 fan hub
Solved by saladcrack,
The hub takes one 4-pin fan header from your motherboard and splits it into all the headers on the fan hub. For the 4-pin it just pushes along the PWM signal like normal but for the 3-in fans it regulates the voltage to control fan speed. A 4-pin fan plugged into a 3-pin header would work like a 3-pin fan
Featured Topics
tommmie20000 ·
Posted in Audio0 -
INotPablo ·
Posted in Cases and Mods0 -
Pove ·
Posted in Power Supplies5 -
Knugen1015 ·
Posted in Windows0 -
1
2
1
10
