CMOS Battery Cause 50% decrease in FPS?
Go to solution Solved by Doge99,
sorry guys there is driver problem i am sorry
Hello
mobo that i use have this CMOS Checksum error so i replace the battery
after that CSGO and Crew receive 50% drop in fps i reduce the quality setting but it did not help at all
so what the problem i am including msinfo.nfo and dxdiag.txt to diagnose the problem
pls help me fast
Thanks
Reagards?????????????
https://linustechtips.com/topic/882815-cmos-battery-cause-50-decrease-in-fps/
you can try this http://ccm.net/faq/1192-lost-bios-password-resetting-the-bios if you can't find a jumper as it mentions post the mobo model you have and maybe we can help, or remove the battery, unplug the psu and try to turn the pc on to drain all the caps in the computer, should work pretty much the same...
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Battery maintains bios settings.
When you pulled out the battery, the settngs were lost and bios probably reset all settings to some default values
Go in bios and check all settings especially ram frequency / xmp profile , m.2 pci-e lanes if you have m.2/nvme drive,
ahci/ide compatibility mode for sata ports (you want ahci), even cpu frequency could be some lower default value.
750ti
78lmt-usb3 rev 5.0
fx 4300
8gb ram 1333 MHz
Edited by xD Power Hole Stick
choose files... Max total size 20MB Choose Files
1 minute ago, xD Power Hole Stick said:
i meant to say that i replace the CMOS battery in under 1 week
Those saved profiles are gone if you replaced the battery in some motherboards.
So with removing the battery your bios would have defaulted its settings.
iE - Slower Ram speeds and such is likely...
DID YOU RE-SETUP YOUR BIOS AFTER BATTERY REINSTALL?
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
so what to do
what about that fps drop
That's fine, but if you computer was unplugged when you changed the battery you probably lost all your setting in you bios, such as overclock on the CPU or Memory that could be the cause for your reduced fps.
i dont overclock the cpu
2 minutes ago, wonderforest said:
I think we are hitting some kind of barrier here guys XD...
Thats why....I'm out.
GL
OP - EVEN WITHOUT CPU OVERCLOCK, BIOS IS BACK TO STOCK DEFAULT AND PARTS ARE SLOWER THAN NORMAL LIKELY
Okkkkk, we are gonna start... well from the START so you'r gonna unplug your computer from the wall and remove your cmos battery for 5min then put it back and see what's what after that.
3 minutes ago, xD Power Hole Stick said:
Delete that message right now!
Don't be a dick, when asked a question,  GO INTO DETAIL WITH ANSWERS if you can, if not, find a technological friend to translate.
Your Parts, plugged into your motherboard,... have to be SETUP in the bios that was reverted to normal values by removing the battery.
Without new values they should be set at, it will likely be slower.
If you have a tech-friend this will be sorted in likely... under a minute.
Or take it to a store, and likely they won't charge you to quickly setup your bios in 60 seconds.
because you are out
i have a problem there is no joke here
i am just getting help i will decide whom should i get help and whom from not to get help ok???
because you are out
I got out, you took offense., thats on you.
I'm not joking here either, without YOU having some basic knowledge, this won't be fixed straight away.
Read your Motherboard Manual on HOW TO SETUP MEMORY SPEEDS, HDD PRIORITY & from there you should be off to a good start.
LUL plz dont be hypersensitive , i've been trying to help you from the start.
see you are just keeping the helper away to help this problem
it is diffcult to drive a car in crew
it is diffcult to drive a aim in CSGO
better to delete
what should i do i resead the GPU it does not work
better to delete
Lost in translation....
It would be much easier if you just read your manual....
GPU has nothing to do with it, unless your not even getting a signal.
If thats the case, this should have been mentioned first.
If your have a signal, Read your Manual & Setup Bios accordingly, or ask a tech-friend to do it for you.
