So I am going to college next year, and I am planning on bringing my desktop.
The problem is that my current rig makes a hellva lot a noise and I don't want to piss of my future roommate.  So I am embarking on a mission to make it as quiet as possible.
I am a dedicated BOINCer, so my CPU and 2 GPUs are always at 100% usage. I'm open to switching cases, cpu/gpu coolers, fans. Specs below
i5 3570k
h100 liquid cooler
660ti with reference cooler & 7770 with reference cooler.
case: Coolermaster HAF 922
fans: 2 coolermaster 200mm & 4 corsair SP fans 120mm
is a passive cooling remotely possible?
HELP PLS!!!
“Obstacles are those frightful things you see when you take your eyes off your goal.”    -Henry Ford
Please do BOINC. no matter how small a contribution it can make a difference.
https://linustechtips.com/topic/88226-help-me-shut-up-my-computer/
Replace all of the fans with Noctua fans and get a fan controller. Passive is not possible here. If there is anything Noctua is good for, it's silence. Also, get a Fractal Design Define R4. Also, mount an Arctic Accelro Extreme III/TT II on the 660 Ti and an Arctic Accelro S1+ on the 7770 with a Noctua fan.
i5 3570k
h100 liquid cooler
HELP PLS!!!
Full custom water cooling loop.  There's no way you are going to passively cool any of that hardware.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
Easiest way: take a pistol and aim to your CPU :P
Hard way: Buy a huge custom loop and some Noctuas, and make them run at 7v, that is silent as heaven.
2 words will help you a lot. NOCTUA FANS
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
first off, change all your fans to Noctua fans.  Get a NZXT G10 water cooler to help lower the noise of your GPU, or use an Asus DCU or DCU 2 GPU cooler.   I would also switch cases to the Fractal Design Define R4 if possible because that will lower the noise but if you take of a side panel the noise will come right back.
Don't bring a desktop to college, with the money you'll spend upgrading your desktop, buy a decent gaming laptop.
VIDEO GAMES                                  Max Power Build Log
If you would like some more appealing fans, that are still quiet, the cougar dual x fans are a good choice too :)
MSI R9 290 Gaming | MSI Z77 MPower Big Bang | XFX Pro 750W Black Edition | i7-3770k @ 4.5GHz | Corsair H100i | GSkill Ripjaw 2x8Gb | NZXT Phantom 410 Gunmetal | OCZ 128 Gb Vertex 4 | Samsung 250Gb 840 EVO | 1&2 Tb Seagate Barracuda | Logitech G510 | Logitech G700 | Logitech G35 | 3 x LG E2442V
-it24-
Didn't you read at the top he uses this rig for mining, a laptop would do terrible at this.
Case: NZXT Phantom 410 Cpu: i7 3820 at 4.3 Ghz Motherboard: Gigabyte GA-X79-UP4 | Gpu: XFX hd 7970 Ghz 1100Mhz/1600Mhz Ram: Crucial BallistiX Elite 16GB 2x8 Gb 1866 Mhz
SSD's: 2x Kingston HyperX 3K SSD 120 GB in RAID 0 HDD:Seagate Barracuda 2TB 7200 Rpm
Cpu cooler: Corsair H100i with SP120's | Psu: Corsair TX 850W My monitors: 3x BenQ 24"  GL2460 = Eyefinity
I did read it and what I am saying is that mining at school... yeah no, not a good idea.
He uses his rig for BOINC, which is not mining.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
oooh sry didn't know that  :mellow:
i5 3570k
h100 liquid cooler
HELP PLS!!!
Move to a quiet case, something like the Corsair Obsidan 550D or Fractal Design Define R4. Switch cpu cooling to an air tower like the Noctua NHU-12S or NH-U14S. The 550D is as quiet as the R4. I doubt there would be a need to add or replace fans. Keeping the number of intakes and exhausts to a minimum helps to contain noise. Removing unused drive bays would provide for better air intake which should help cooling the gpu.
Gaming and laptop don't belong in the same sentence.
Those reference coolers will make noise, a lot of it.
Listen if you care.
Corsair fans  and reference coolers are pretty loud. The OP has SP120's which are darn loud.
